09-19-2024
01:21 AM
- Mute
- Permalink
- Report
09-19-2024
01:21 AM
- Are both the iLogic Form, and the iLogic rule that are being called to show / run located within your drawing template file?
An external rule fires an internal form and rule
- Are you using the event in the Event Triggers dialog named "New Document" only ; or are you also using additional events in the Event Triggers ; or are you using custom event handler codes, such as within an Inventor add-in? Please be as specific and informational as possible.
Just event trigger to fire external rule on new drawing
- Do you ever create a visible new drawing from that template by code?
- no
- If so, then does that trigger this event, showing the Form and running the rule?
- Does the SheetFormat being used to create a new Sheet contain any model views?
- no
- Does the SheetFormat being used to create a new Sheet contain any 'linked' properties which point to 'the model'?
- no
