donald_leigh
in reply to: donald_leigh
Here is the revised code.
Sub Main()
    Dim oDoc As DrawingDocument = ThisDoc.Document
    Dim oSheet As Sheet = oDoc.ActiveSheet
    ' Iterate through each view in the active sheet
    For Each oView As DrawingView In oSheet.DrawingViews
        Dim oViewLabel As DrawingViewLabel = oView.Label
        Dim defaultY As Double = oView.Top - oView.Height
        ' Initialize a variable to track the lowest dimension Y position under the view
        Dim lowestDimensionY As Double = defaultY
        ' Check each dimension in the sheet
        For Each oDim As DrawingDimension In oSheet.DrawingDimensions
            ' Check if the dimension is associated with the current view and if its text is below the view
            If IsDimensionAssociatedWithView(oDim, oView) AndAlso IsDimensionTextUnderView(oDim, oView) Then
                Dim dimTextY As Double = oDim.Text.Origin.Y
                ' Find the lowest dimension text Y-coordinate
                If dimTextY < lowestDimensionY Then
                    lowestDimensionY = dimTextY
                End If
            End If
        Next
        ' Determine the final Y position for the label
        Dim finalY As Double
        If lowestDimensionY < defaultY Then
            finalY = lowestDimensionY - 1 ' Adjust the label's Y position slightly below the lowest dimension
        Else
            finalY = defaultY - 1 ' Adjust slightly below the view's default Y position
        End If
        ' Calculate the X position (centered horizontally relative to the view)
        Dim defaultX As Double = oView.Left + (oView.Width / 2)
        ' Create a new Point2D for the label position
        Dim newPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(defaultX, finalY)
        ' Update the view label position
        oViewLabel.ConstrainToBorder = False
        oViewLabel.Position = newPosition
    Next
    ' Update the drawing and refresh the view
    oDoc.Update()
    ThisApplication.ActiveView.Update()
End Sub
' Function to check if the dimension is associated with the given view
Function IsDimensionAssociatedWithView(oDim As DrawingDimension, oView As DrawingView) As Boolean
    Try
        ' For linear and angular dimensions, use IntentOne and IntentTwo
        Dim intentOne As GeometryIntent = oDim.IntentOne
        Dim intentTwo As GeometryIntent = oDim.IntentTwo
        ' Check if either geometry intent belongs to the view
        If (intentOne IsNot Nothing AndAlso intentOne.Geometry IsNot Nothing AndAlso intentOne.Geometry.Parent Is oView) OrElse
           (intentTwo IsNot Nothing AndAlso intentTwo.Geometry IsNot Nothing AndAlso intentTwo.Geometry.Parent Is oView) Then
            Return True
        End If
    Catch ex As Exception
        ' Handle exceptions, especially for dimensions that do not have IntentOne and IntentTwo
    End Try
    Return False
End Function
' Function to check if the dimension's text is below the view
Function IsDimensionTextUnderView(oDim As DrawingDimension, oView As DrawingView) As Boolean
    Dim dimTextOrigin As Point2d = oDim.Text.Origin
    ' Check if the dimension text is horizontally within the view's extents
    If dimTextOrigin.X >= oView.Left AndAlso dimTextOrigin.X <= (oView.Left + oView.Width) Then
        ' Check if the dimension text is below the bottom of the view
        If dimTextOrigin.Y < (oView.Top - oView.Height) Then
            Return True
        End If
    End If
    Return False
End Function
