HogueOne
in reply to: donald_leigh
I don't know if you found your answer, but I had a similar problem. this is what worked for me:
Sub Main()
    Dim oDoc As DrawingDocument = ThisDoc.Document
    Dim oSheet As Sheet = oDoc.ActiveSheet
    For Each oView As DrawingView In oSheet.DrawingViews
        Dim oViewLabel As DrawingViewLabel = oView.Label
        Dim defaultY As Double = oView.Top - oView.Height
        ' Check for dimensions below the view
        Dim lowestDimensionY As Double = defaultY
        For Each oDim As DrawingDimension In oSheet.DrawingDimensions
            If IsDimensionAssociatedWithView(oDim, oView) AndAlso
               IsDimensionTextUnderView(oDim, oView) Then
                Dim dimTextY As Double = oDim.Text.Origin.Y
                If dimTextY < lowestDimensionY Then
                    lowestDimensionY = dimTextY
                End If
            End If
        Next
        ' Determine the final Y position for the label
        Dim finalY As Double
        If lowestDimensionY < defaultY Then
            finalY = lowestDimensionY - oDoc.UnitsOfMeasure.ConvertUnits(2, kCentimeterLengthUnits, oDoc.UnitsOfMeasure.LengthUnits)
        Else
            finalY = defaultY - oDoc.UnitsOfMeasure.ConvertUnits(2, kCentimeterLengthUnits, oDoc.UnitsOfMeasure.LengthUnits)
        End If
        ' Calculate the X position (centered horizontally)
        Dim defaultX As Double = oView.Left + (oView.Width / 2)
        ' Create a new Point2D for the position
        Dim newPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(defaultX, finalY)
        ' Move the view label to the new position
        oViewLabel.ConstrainToBorder = False
        oViewLabel.Position = newPosition
    Next
    ' Update the drawing and refresh the graphics
    oDoc.Update()
    ThisApplication.ActiveView.Update()
End Sub
Function IsDimensionAssociatedWithView(oDim As DrawingDimension, oView As DrawingView) As Boolean
    ' Check if the dimension is associated with the view
    Dim intentOne As GeometryIntent = oDim.IntentOne
    Dim intentTwo As GeometryIntent = oDim.IntentTwo
    ' Check if either of the intents' geometry belongs to the view
    If (intentOne.Geometry IsNot Nothing AndAlso intentOne.Geometry.Parent Is oView) OrElse
       (intentTwo.Geometry IsNot Nothing AndAlso intentTwo.Geometry.Parent Is oView) Then
        Return True
    End If
    Return False
End Function
Function IsDimensionTextUnderView(oDim As DrawingDimension, oView As DrawingView) As Boolean
    Dim dimTextOrigin As Point2d = oDim.Text.Origin
    ' Check if the dimension text is between the left and right extents of the view
    If dimTextOrigin.X >= oView.Left AndAlso dimTextOrigin.X <= (oView.Left + oView.Width) Then
        ' Check if the dimension text is below the bottom of the view
        If dimTextOrigin.Y < (oView.Top - oView.Height) Then
            Return True
        End If
    End If
    Return False
End Function
