- Mute
- Permalink
- Report
I created a custom addin project, This addin has a Test button in the ribbon.
The button click event will add a new BrowserPane to the active document. Im using AddByManifest to load the un managed active x control.
During the execution of AddByManifest() the temporary MessageBox in the FormLoad event will shown, which makes me think that the control is loaded properly.
But when i try to access the BrowsePane.Control property, It is throwing an exception.
Does anyone have an idea on how to fix this problem ?
I attached the CustomAddin that i created.
Thank you
- Mute
- Permalink
- Report
I looked into your code and I don't understand why you need to use BrowserPane when the requested content is derived from Windows.Forms.UserControl.
Isn't it better to use DockableWindow? C# sample is available for example here on my GitHub
Method BrowserPanes.AddByManifest is designed for placing ActiveX objects which is not your case in my opinion.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
