BenAtok
260 Views, 4 Replies
In the assembly drawing, a ModelGeometry.ContainingOccurrence error occurs.
I'm trying to write a program that checks which parts are not ballooned in the BOM and then goes through all the drawing curves in the assembly drawing to balloon them. However, an error occurs when attempting to get ModelGeometry from DrawingCurve (line 38). Can someone help me resolve this issue?
Public Sub CheckPartsList()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    Dim oPartsList As PartsList
    Set oPartsList = oActiveSheet.PartsLists(1)
    Dim oPartslistRow As PartsListRow
    Dim lstOfComponents As String
    For Each oPartslistRow In oPartsList.PartsListRows
        If oPartslistRow.Ballooned = False Then
            Dim ItemNumber As String
            ItemNumber = oPartslistRow.Item(5).Value
            lstOfComponents = ItemNumber
        End If
    Next
    Dim oDrawView As DrawingView
    Set oDrawView = oActiveSheet.DrawingViews.Item(1)
    Dim oDrawCurves As DrawingCurvesEnumerator
    Set oDrawCurves = oDrawView.DrawingCurves
    Dim oDrawCurve As DrawingCurve
    Dim oCurveModelGeometry As Object
    Dim oCurveContainingOccurence As Object
    Dim PartNameFromCurve
    For Each oDrawCurve In oDrawCurves
        Set oCurveModelGeometry = oDrawCurve.ModelGeometry
        '-------------delet part name from ":"
        Set oCurveContainingOccurence = oCurveModelGeometry.ContainingOccurrence
        PartNameFromCurve = oCurveContainingOccurence.Name
        colonPosition = InStr(PartNameFromCurve, ":")
        If colonPosition > 0 Then
            ConfiguredPartNameFromCurve = Left(PartNameFromCurve, colonPosition - 1)
        Else
            ConfiguredPartNameFromCurve = PartNameFromCurve
        End If
        '-----------compare part name from BOM and Drawingcurve
        If ConfiguredPartNameFromCurve = lstOfComponents Then
            MsgBox (PartNameFromCurve)
            Exit For
        End If
    Next
    Stop
End Sub
