08-23-2024
03:02 AM
- Mute
- Permalink
- Report
08-23-2024
03:02 AM
Hi, this could be a start
If the first view reference is an assembly document and if the assembly document references a custom property a message box will appear with value.
Sub main Dim CustomProp As String = "CustompropName" 'property to be found change this Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet = oDrawDoc.ActiveSheet If oSheet.DrawingViews.Count = 0 Then Exit Sub Dim oView As DrawingView = oSheet.DrawingViews.Item(1) 'firts view to be found Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oCustomprop As Inventor.Property = GetCustomprop(oDoc, CustomProp) If oCustomprop IsNot Nothing Then Dim oCustompropValue As String = oCustomprop.Value MsgBox(oCustompropValue) End If End If End Sub Private Function GetCustomprop(AssyDoc As AssemblyDocument, CustomProp As String) As Inventor.Property Dim result As Inventor.Property = Nothing Try ' Get the PropertySets object. Dim oPropSets As PropertySets = AssyDoc.PropertySets ' Get the design tracking property set. Dim oPropSet As Inventor.PropertySet = oPropSets.Item("Inventor User Defined Properties") ' Get the part number iProperty. Dim oPartNumiProp As Inventor.Property = oPropSet.Item(CustomProp) result = oPartNumiProp Catch ex As Exception End Try Return result End Function
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
