Fazlur_Rahaman
210 Views, 4 Replies
Item Number, description call out under drawing view
Hey guys, I have the code below to call out the Item number, description and the Stock number. The code works flawlessly. But I want to modify it to just call out the Active sheet, not the whole document.  Can someone help me with it please?
'This assumes a drawing document is active.
 'Dim oDrawDoc As DrawingDocument
 oDrawDoc = ThisApplication.ActiveDocument
 Dim oSheets As Sheets
 Dim Sheet As Inventor.Sheet
 Dim oViews As DrawingViews
 Dim oView As DrawingView
 For Each oSheet In oDrawDoc.Sheets
 'For Each oSheet In oSheets
     oViews = oSheet.DrawingViews
     For Each oView In oViews
         'Get the full filename Of the view model
         Dim oModelFileName As String
         oModelFileName = oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
         'MessageBox.Show("view model name" & oModelFileName, "Title")
         Dim oPartList As PartsList
             'try and get the parts list form the table of this sheet
             Try
                 oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
             Catch 'on error try and search all sheets for first found parts list
                 'iterate trough each sheet
                 Dim i As Long
                 For i = 1 To oDrawDoc.Sheets.Count
                     If oDrawDoc.Sheets.Item(i).PartsLists.Count > 0 Then Exit For
                 Next
                 oPartList = oDrawDoc.Sheets.Item(i).PartsLists.Item(1)
                 'MessageBox.Show("parts list found on: " & i, "Title")
             End Try
             ' Iterate through the contents of the parts list.
             Dim j As Long
             For j = 1 To oPartList.PartsListRows.Count
                 ' Get the current row.
                 Dim oRow As PartsListRow
                 oRow = oPartList.PartsListRows.Item(j)
                 'get filename of model in row
                 Dim oRowFileName As String
                 ''oRowFileName = oRow.ReferencedFiles.Item(1).FullFileName
				 Try 'and get the full file name of the PL item
				      Catch 'on error go To Next item
					  Continue For
				 End Try
                 'compare the filenames
                 'Performs a text comparison, based on a case-insensitive text sort order
                 'If strings equal returns 0
                 If StrComp(oModelFileName, oRowFileName, CompareMethod.Text)=0 Then
                     'Get the value of Item from the Parts List
                     'Row name needs to be case sensitive or use 1 for first 2 for second etc.
                     oCell  = oPartList.PartsListRows.Item(j).Item("Item") 'Row name needs to be case sensitive or use 1 for first 2 for second etc.
                     'get the value of text in cell
                     Dim oItemValue As String
                     oItemValue = oCell.Value
                     'Show the view label
                     oView.ShowLabel = True
                     'format the text first line
                     ''oStringItem = "<StyleOverride Underline='True' FontSize='0.35'> ITEM  " & "''" & oItemValue & "''" & "  DETAIL" & " </StyleOverride>"
                     If oView.ViewType = 10501 Then
					oStringItem = "<StyleOverride Underline='True' FontSize='0.35'> ITEM" & " ''" & oItemValue & "''" & " DETAIL" & " </StyleOverride>"
					'format the text second line
					oPartNumber = "<Br/><StyleOverride Underline='False' FontSize='0.25'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
					oDescription = "<Br/><StyleOverride Underline='False' FontSize='0.25'><Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>DESCRIPTION</Property></StyleOverride>"
					oDXF = "<Br/><StyleOverride Underline='False' FontSize='0.25'>DXF FILE:<Property Document='model' PropertySet='Design Tracking Properties' Property='Stock Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>STOCK NUMBER</Property></StyleOverride>"
					'add to the view label
					End If
                     'oStringScale = "<Br/><StyleOverride FontSize='0.3'>(Scale <DrawingViewScale/>)</StyleOverride>"
                     oView.Label.FormattedText =  oStringItem & oPartNumber & oDescription & oDXF
                 End If
             Next
       Next
 Next
