08-13-2024
10:07 AM
- Mute
- Permalink
- Report
08-13-2024
10:07 AM
Also, here is a version that uses a preset/hardcoded color, in case that is preferred over the color picker.
Just change the hardcoded R, G, B values in bold to change the color
You can look up RGB values for colors here:
https://www.rapidtables.com/web/color/RGB_Color.html
Sub Main Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences Dim oColor As Asset = GetColor() ' Ensure that a color has been selected If oColor Is Nothing Then MessageBox.Show("No color selected. Exiting the script.") Exit Sub End If ' Traverse the assembly and color parts where CompliantWithMachine is False Call TraverseAssembly(oOccs, oColor) ' Show completion message MessageBox.Show("Coloring successfully completed.") End Sub Sub TraverseAssembly(oOccs As ComponentOccurrences, oColor As Asset) Dim oOcc As ComponentOccurrence For Each oOcc In oOccs If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, oColor) ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then 'set default isCompliant = True Try isCompliant = iProperties.Value(oOcc.Name, "Custom", "CompliantWithMachine") Catch ' If the property is missing or an error occurs, do not color the part End Try If isCompliant = False Then oOcc.Appearance = oColor End If Next End Sub Function GetColor() As Asset 'hard coded color values 'https://www.rapidtables.com/web/color/RGB_Color.html oRed = 255 oGreen = 0 oBlue = 0 Dim oName As String = "Paint Color" Dim oAppearance As Asset Try 'create new appearance oAppearance = ThisDoc.Document.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "Appearances", oName) Catch oAppearance = ThisDoc.Document.Assets.Item(oName) End Try 'set colors Dim oNewColor As ColorAssetValue oNewColor = oAppearance.Item("generic_diffuse") oNewColor.Value = ThisApplication.TransientObjects.CreateColor(oRed, oGreen, oBlue) Return oAppearance End Function
