- Mute
- Permalink
- Report
Hi Curtis,
Thank you so much! The code works very well. Now I'm trying to improve the code where the user does not need to supply a list of part names as strings separated by comma, because usually an assembly has too many parts that needs to be colored.
I'm adding the functionality where instead of MyList, the code will parse through the assembly, read the iProperty information, and color the part where "CompliantWithMachine" = No.
The "Compliant with Machine" is a custom iProperty, the type is Yes or No. I'm trying to make the code do three things:
1. If Compliant with Machine = No, color the part
2. If Compliant with Machine = Yes, don't color the part
3. If Compliant with Machine doesn't exist for a part, don't color the part.
My current code is below:
Imports System.ComponentModel
AddReference "System.drawing"
Imports System.Windows.Forms
Imports System.Drawing
Sub Main
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
Dim oColor As Asset = GetColor()
' Ensure that a color has been selected
If oColor Is Nothing Then
MessageBox.Show("No color selected. Exiting the script.")
Exit Sub
End If
' Traverse the assembly and color parts where CompliantWithMachine is False
Call TraverseAssembly(oOccs, oColor)
' Show completion message
MessageBox.Show("Coloring successfully completed.")
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences, oColor As Asset)
Dim oOcc As ComponentOccurrence
For Each oOcc In oOccs
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Call TraverseAssembly(oOcc.SubOccurrences, oColor)
ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Try
' Get the "CompliantWithMachine" property value as a Boolean
Dim CompliantWithMachine As Boolean = False ' Default to False in case of any issues
CompliantWithMachine = oOcc.Definition.PropertySets("Inventor User Defined Properties")("CompliantWithMachine").Value
' Check the property value
If Not CompliantWithMachine Then
' If property = False (equivalent to "No"), color the part
oOcc.Appearance = oColor
Else
End If
Catch
' If the property is missing or an error occurs, do not color the part
End Try
End If
Next
End Sub
Function GetColor() As Asset
Dim oClDlg As New System.Windows.Forms.ColorDialog
Dim oColor As System.Drawing.Color
If oClDlg.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
oColor = oClDlg.Color
Else
Return Nothing
End If
Dim oName As String = "Paint Color"
Dim oAppearance As Asset
Try 'create new appearance
oAppearance = ThisDoc.Document.Assets.Add(AssetTypeEnum.kAssetTypeAppearance,
"Generic", "Appearances", oName)
Catch
oAppearance = ThisDoc.Document.Assets.Item(oName)
End Try
'set colors
Dim oNewColor As ColorAssetValue
oNewColor = oAppearance.Item("generic_diffuse")
oNewColor.Value = ThisApplication.TransientObjects.CreateColor(oColor.R, oColor.G, oColor.B)
Return oAppearance
End FunctionWhen I run the code, no parts are colored.
When I add debugging messages, it shows that all parts are identified as the property doesn't exist, which is not true.
Could you help me with this issue? Thank you so much!
