08-12-2024
02:42 AM
- Mute
- Permalink
- Report
08-12-2024
02:42 AM
I am creating a tool that auto-dimension's drawings. The tolerances placed on the sheet are a factor of 10 higher than what I have set them to in iLogic. All my dimensions are in mm. What am I missing?
Code for the manage section:
ThisDrawing.BeginManage() If True Then Dim BSPPLength1 = genDims.AddLinear("dimension 1", VIEW1.SheetPoint(1, 1.2), HexEdge, F4) : BSPPLength1.NativeEntity.Tolerance.SetToDeviation(0.2, -0.0) : BSPPLength1.NativeEntity.TolerancePrecision.Equals(3) Dim BSPPLength2 = genDims.AddLinear("dimension 2", VIEW1.SheetPoint(1, 1.1), HexEdge, E2) Dim BSPPLength3 = genDims.AddLinear("dimension 3", VIEW1.SheetPoint(1, 1), HexEdge, E1) : BSPPLength3.NativeEntity.Tolerance.SetToDeviation(0.2, -0.0) Dim BSPPSealAngle = genDims.AddAngular("Dimension 4", VIEW1.SheetPoint(-0.1, 0.5), SealPoint1, SealPoint2) : BSPPSealAngle.NativeEntity.Tolerance.SetToDeviation(0, -0.5*0.174533) Dim BSPPInternalDiameter = genDims.AddLinear("dimension 7", VIEW1.SheetPoint(-0.2, 0.5), InternalFace1, InternalFace2) Dim BSPPSealingDia = genDims.AddDiameter("dimension 5", VIEW1.SheetPoint(-0.3, 0.5), F4, True) : BSPPSealingDia.NativeEntity.Tolerance.SetToSymmetric(0.12) Dim BSPPDiaE3 = genDims.AddDiameter("dimension 6", VIEW1.SheetPoint(-0.4, 0.5), E3, True) : BSPPDiaE3.NativeEntity.Tolerance.SetToDeviation(0, -0.12) Dim BSPPDiaE2 = genDims.AddDiameter("dimension 8", VIEW1.SheetPoint(-0.5, 0.5), E2, True) : BSPPDiaE2.NativeEntity.Tolerance.SetToDeviation(0, -0.25) Dim BSPPDiaLatchGroove = genDims.AddLinear("dimension 9", VIEW1.SheetPoint(0.6, -0.5), BSPPLatchGroove1, BSPPLatchGroove2,,,False) : BSPPDiaLatchGroove.NativeEntity.Tolerance.SetToDeviation(0, -0.1) End If ThisDrawing.EndManage()
Drawing with tolerances 10 times higher:
Many thanks,
Harvey
