- Mute
- Permalink
- Report
Hi all,
I want to write an iLogic code that will do the following actions:
1. I will give a list of part names as input
2. The code will parse through a big assembly file (that contains sub-assemblies) to find the parts, and color all of them to a certain color
I have a working version for a code that works for a simple assembly where there's no sub-assembly:
' iLogic rule To color parts In an assembly Using Partial part names
' List of part names (or partial names) to color
Dim partsToColor As String() = {"SAG3YZM5" } ' Add other part names as needed
Dim partsToColorCount As Integer = partsToColor.Length ' Count the number of elements in list so we can set the loop size
Dim colorStyleName As String = "Magenta" ' Replace with desired color style name
' Loop through each component in the assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oCompOccs As ComponentOccurrences
oCompOccs = oAssyDoc.ComponentDefinition.Occurrences
For Each oOcc As ComponentOccurrence In oCompOccs
' Check if the component name contains any of the specified part names
For Index = 1 To partsToColorCount
If oOcc.Name.Contains(partsToColor(Index - 1)) Then 'Subtract 1 since the index of the first element in the array is 0
' Try to set the color of the component
Try
Component.Color(oOcc.Name) = colorStyleName
MessageBox.Show("Colored component: " & oOcc.Name)
Catch
MessageBox.Show("Error setting color for component: " & oOcc.Name)
End Try
End If
Next
NextHowever, when I try to expand this to bigger assemblies, I couldn't get the code to work:
Sub Main
oAssyDocType = oAssyDoc.DocumentType
If oAssyDocType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MessageBox.Show("This process only runs on assemblies.")
Exit Sub
Else
Call ColorAssembly
End If
End Sub
Sub ColorAssembly(AssyDocument As AssemblyDocument, FileList())
If oOcc Is On FileList() Then
Call ColorPart
ElseIf oOcc = Assembly
Call ColorAssembly()
End If
Next
End Sub
Sub ColorPart(OccurenceInAssy As Occurrence)
Try
Catch
End Try
End If
Next
Next
End SubHere, the code will:
1. Check if an occurrence is a part or assembly
2. If it's a part, then execute the ColorPart subroutine; if it's an assembly, call ColorAssembly subroutine, where it goes into the assembly and look for the parts.
I couldn't get the code to work, and I'm fairly new to VBA. Could anyone help me with my issue?
Thank you so much!
