jeyuan
414 Views, 6 Replies
How to auto change part color for a big assembly with sub-assemblies
Hi all,
I want to write an iLogic code that will do the following actions:
1. I will give a list of part names as input
2. The code will parse through a big assembly file (that contains sub-assemblies) to find the parts, and color all of them to a certain color
I have a working version for a code that works for a simple assembly where there's no sub-assembly:
' iLogic rule To color parts In an assembly Using Partial part names
' List of part names (or partial names) to color
Dim partsToColor As String() = {"SAG3YZM5" } ' Add other part names as needed
Dim partsToColorCount As Integer = partsToColor.Length ' Count the number of elements in list so we can set the loop size
Dim colorStyleName As String = "Magenta" ' Replace with desired color style name
' Loop through each component in the assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oCompOccs As ComponentOccurrences
oCompOccs = oAssyDoc.ComponentDefinition.Occurrences
For Each oOcc As ComponentOccurrence In oCompOccs
	' Check if the component name contains any of the specified part names
	For Index = 1 To partsToColorCount
		If oOcc.Name.Contains(partsToColor(Index - 1)) Then 'Subtract 1 since the index of the first element in the array is 0
			' Try to set the color of the component
			Try
				Component.Color(oOcc.Name) = colorStyleName
				MessageBox.Show("Colored component: " & oOcc.Name)
			Catch
				MessageBox.Show("Error setting color for component: " & oOcc.Name)
			End Try
		End If
	Next
Next
However, when I try to expand this to bigger assemblies, I couldn't get the code to work:
Sub Main
	oAssyDocType = oAssyDoc.DocumentType
	If oAssyDocType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MessageBox.Show("This process only runs on assemblies.")
		Exit Sub
	Else
		Call ColorAssembly
	End If
End Sub
Sub ColorAssembly(AssyDocument As AssemblyDocument, FileList())
		If oOcc Is On FileList() Then
			Call ColorPart
		ElseIf oOcc = Assembly
			Call ColorAssembly()
		End If
	Next
End Sub
Sub ColorPart(OccurenceInAssy As Occurrence)
				Try
				Catch
				End Try
			End If
		Next
	Next
End Sub
Here, the code will:
1. Check if an occurrence is a part or assembly
2. If it's a part, then execute the ColorPart subroutine; if it's an assembly, call ColorAssembly subroutine, where it goes into the assembly and look for the parts.
I couldn't get the code to work, and I'm fairly new to VBA. Could anyone help me with my issue?
Thank you so much!
Curtis_Waguespack
in reply to: jeyuan
@jeyuan, here is an ilogic example that changes the color of all the parts in all sub assemblies, but only applies the colors at the top level assembly.
meaning if you open the parts their color are not changed at that level, and if you open the subassemblies the part colors are not changed at that level... but they all get the color override in the top level assembly.
( p.s. thanks to @Stakin who supplied the color picker example recently)
Imports System.ComponentModel
AddReference "System.drawing"
Imports System.Windows.Forms
Imports System.Drawing
Sub Main
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	Dim oColor As Asset = GetColor
	Call TraverseAssembly(oOccs, oColor)
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences, oColor As Asset)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Call TraverseAssembly(oOcc.SubOccurrences, oColor)
		ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
			oOcc.Appearance = oColor
		End If
	Next
End Sub
Function GetColor() As Asset
	Dim oClDlg As New System.Windows.Forms.ColorDialog
	Dim oColor As System.drawing.Color
	If oClDlg.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
		oColor = oClDlg.Color
	End If
	oName = "Paint Color"
	Dim oAppearance As Asset
	Try 	'create new appearance
		oAppearance = ThisDoc.Document.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "Appearances", oName)
	Catch
		oAppearance = ThisDoc.Document.Assets.item(oName)
	End Try
	'set colors
	Dim oNewColor As ColorAssetValue
	oNewColor = oAppearance.Item("generic_diffuse")
	oNewColor.Value = ThisApplication.TransientObjects.CreateColor(oColor.R, oColor.G, oColor.B)
	Return oAppearance
End Function
Curtis_Waguespack
in reply to: jeyuan
A quick update to the previous example, this one only colors components named in a list
Sub Main
	Dim myList As New List(Of String)(New String() {"Foo", "Foo Too" }) 'list with part names
	Call TraverseAssembly(oOccs, oColor, myList)
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences, oColor As Asset, myList As List(Of String))
			Call TraverseAssembly(oOcc.SubOccurrences, oColor, myList)
			If myList.Contains(oOcc.Name) Then oOcc.Appearance = oColor
		End If
	Next
End Sub
	End If
	Catch
	End Try
	'set colors
	Return oAppearance
End Function
jeyuan
in reply to: Curtis_Waguespack
Hi Curtis,
Thank you so much! The code works very well. Now I'm trying to improve the code where the user does not need to supply a list of part names as strings separated by comma, because usually an assembly has too many parts that needs to be colored.
I'm adding the functionality where instead of MyList, the code will parse through the assembly, read the iProperty information, and color the part where "CompliantWithMachine" = No.
The "Compliant with Machine" is a custom iProperty, the type is Yes or No. I'm trying to make the code do three things:
1. If Compliant with Machine = No, color the part
2. If Compliant with Machine = Yes, don't color the part
3. If Compliant with Machine doesn't exist for a part, don't color the part.
My current code is below:
Sub Main
	Dim oColor As Asset = GetColor()
	' Ensure that a color has been selected
	If oColor Is Nothing Then
		MessageBox.Show("No color selected. Exiting the script.")
		Exit Sub
	End If
	' Traverse the assembly and color parts where CompliantWithMachine is False
	' Show completion message
	MessageBox.Show("Coloring successfully completed.")
End Sub
			Try
				' Get the "CompliantWithMachine" property value as a Boolean
				Dim CompliantWithMachine As Boolean = False ' Default to False in case of any issues
				CompliantWithMachine = oOcc.Definition.PropertySets("Inventor User Defined Properties")("CompliantWithMachine").Value
				' Check the property value
				If Not CompliantWithMachine Then
					' If property = False (equivalent to "No"), color the part
				Else
				End If
			Catch
				' If the property is missing or an error occurs, do not color the part
			End Try
		End If
	Next
End Sub
	Dim oColor As System.Drawing.Color
	Else
		Return Nothing
	End If
	Dim oName As String = "Paint Color"
	Catch
		oAppearance = ThisDoc.Document.Assets.Item(oName)
	End Try
	'set colors
	Return oAppearance
End Function
When I run the code, no parts are colored.
When I add debugging messages, it shows that all parts are identified as the property doesn't exist, which is not true.
Could you help me with this issue? Thank you so much!
Curtis_Waguespack
in reply to: jeyuan
HI @jeyuan , give this version a try
Sub Main
		Exit Sub
	End If
End Sub
			'set default
			isCompliant = True
			Try
				isCompliant = iProperties.Value(oOcc.Name, "Custom", "CompliantWithMachine")
			Catch
			End Try
			If isCompliant = False Then oOcc.Appearance = oColor
		End If
	Next
End Sub
	Else
		Return Nothing
	End If
	Catch
	End Try
	'set colors
	Return oAppearance
End Function
Curtis_Waguespack
in reply to: jeyuan
Also, here is a version that uses a preset/hardcoded color, in case that is preferred over the color picker.
Just change the hardcoded R, G, B values in bold to change the color
You can look up RGB values for colors here:
https://www.rapidtables.com/web/color/RGB_Color.html
Sub Main
		Exit Sub
	End If
End Sub
			'set default
			isCompliant = True
			Try
			Catch
			End Try
		End If
	Next
End Sub
	'hard coded color values
	'https://www.rapidtables.com/web/color/RGB_Color.html
	oRed = 255
	oGreen = 0
	oBlue = 0
	Catch
	End Try
	'set colors
	oNewColor.Value = ThisApplication.TransientObjects.CreateColor(oRed, oGreen, oBlue)
	Return oAppearance
End Function
jeyuan
That works very well for me! Thank you for your help!
