roy7BB24
in reply to: JelteDeJong
The idea is the graphic will be shown on one of the A2 drawing sheets that shows the construction details for a major assembly. As such there's a number of size constraints where a standard BOM format just isn't efficient. I would also like a format that's a bit more intuitive and easier to read. I don't need to show a ton of detailed information, it's probably as simple as just quantities, part numbers and a very simple descriptor.
Based on this I think my current approach is going to be create a script that creates the diagram as a 3D model. There will be a significant amount of coding in this, but I think I'll just chip away at it. Staying within inventor means I can pull in derived models of the assembly stages if I decide to go down that route for added polish.
Anyway, I haven't been able to find anything to copy or emulate that's similar to what I want so I guess I'm starting from scratch
Kind Regards
Roydon Mackay
