- Mute
- Permalink
- Report
Hi @ChristianAhlers. I am not familiar with writing code in C#.net, but I can follow your code OK, due to how similar it is to vb.net. I just checked on the Form.ShowDialog official documentation website (link below), and it says that this applies to .NET Framework 4.8.1 and other versions. It does not mention regular .NET, so I can only assume that it will no longer work with the newer system being used in Inventor 2025, since they stepped forward to using regular .NET.
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.form.showdialog
Same for the DialogResult Enum..., because it is .NET Framework 4.8.1 (and earlier), and Windows Desktop 9 and earlier.
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.dialogresult
I will be interested in seeing the next best alternatives myself, because I still use that method in several of the solutions where I work.
Edit: The System.Windows.Forms.Form object is the same way. I am not sure if the whole System.Windows.Froms Namespace is only supported in those code systems listed above or not.
Wesley Crihfield
(Not an Autodesk Employee)
