- Mute
- Permalink
- Report
Hello
when creating an assembly i create Custom work planes that represent the "Ground" or other theoretical levels. i normally show them using the "include" feature on the idw, I manually search my workplane name on the browser.
I'm trying to automate it in a way that ilogic searches for any specific string like the word "Ground" and will automatically include it on any view possible. I understand some views cannot include them. the program should skip to the next view. is this feature accessible through ilogic?
- Mute
- Permalink
- Report
Hi @Alexrose1942 . Please try this code. You need to write down your keywords in line 3 (example: {"Ground", "abc", "qwert"}).
Dim oDDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
If oDDoc Is Nothing Then Exit Sub
Dim sList() As String = {"Ground"}
For Each oSheet As Sheet In oDDoc.Sheets
For Each oView As DrawingView In oSheet.DrawingViews
Dim oRefDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
For Each oPlane As WorkPlane In oRefDoc.ComponentDefinition.WorkPlanes
For i As Integer = 0 To sList.Length - 1
If Not oPlane.Name.Contains(sList(i)) Then Continue For
Try : oView.SetIncludeStatus(oPlane, True) : Catch : End Try
Next i
Next
Next
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
- Mute
- Permalink
- Report
