c_hoppen
in reply to: WCrihfield
It's getting stranger and stranger...
With my test assembly (2650 files & 10000 Occurrences), the following code takes about 1.5 seconds. Always. The assembly is already open.
ComponentOccurrences occs = assmDoc.ComponentDefinition.Occurrences;
foreach (Document document in assmDoc.AllReferencedDocuments)
    if (IsMatching(document, sd))
        ComponentOccurrencesEnumerator leafOccs = occs.get_AllReferencedOccurrences(document);
        foreach (ComponentOccurrence occ in leafOccs)
            oCol.Add(occ);
Traversing the assembly occurrences leads to the same result:
foreach (ComponentOccurrence occ in assmDoc.ComponentDefinition.Occurrences)
    if (IsMatching(occ.Definition.Document as Document, sd))
        oCol.Add(occ);
    if (occ.SubOccurrences.Count > 0)
        TraverseAssembly(occ.SubOccurrences, sd, oCol);
private static void TraverseAssembly(ComponentOccurrencesEnumerator subOccurrences, SearchDefinition sd, ObjectCollection oCol)
    foreach(ComponentOccurrence occ in subOccurrences)
            oCol.Add(occ);
But it takes 17 seconds for the first call, and a quick glance for subsequent calls ( < 500 mSec).
