WCrihfield
in reply to: c_hoppen
Usually, if we can not do it manually, then we can not do it by code either.  When I click on the search icon at the top of my model browser tree, I get something that looks like this:
There are 3 icons under the search box.  The second and third icons coincide with those two filters within the SearchBoxFilterEnum.  The icon on the far left looks like a greyed out funnel until one or more of those other two are selected, then it looks like an 'X'.  Then when you click the 'X', that clears any 'filters' that were selected before.
I agree that it would be pretty nice if that Search functionality were more dynamic / powerful.
If you need to find only the assembly components which have "gk" as the value of their 'Author' iProperty, then you will likely need to do so with an iLogic rule (or similar).  Another way to see them might be to open the BOM, and include a column for that iProperty, so you can see which ones have that value.  The rows could likely be sorted by the values in that column also.  If you would like to go the iLogic rule route, and would like some help with that, just let us know.
Wesley Crihfield
(Not an Autodesk Employee)
