Function ParameterExists(paramName As String) As Boolean
	Dim doc As Document = ThisDoc.Document
	Dim params As Parameters
	If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
		params = doc.Parameters
	Else
		params = doc.ComponentDefinition.Parameters
	End If
	For Each p As Parameter In params
		If p.Name = paramName Then Return True
	Next p
	Return False
End Function 'ParameterExists
You can add this function to your code - it'll return True if the parameter name you give it exists in the document.
