m_baczewski
in reply to: ccoomes
You can using this code. You should insert the parameters you want to search.
mSearchParams.Add("Name", "YourNameWithExtension")
'Build one to many name/value pairs of Property/Value as search criteria
	Dim mSearchParams As New System.Collections.Generic.Dictionary(Of String, String) 'add UDP.DisplayName, Value Pairs
	'returns full file name in local working folder (download enforces override, if local file exists)
	mVaultFile = iLogicVault.GetFileBySearchCriteria(mSearchParams, True, True) ', True: combine search criteria by AND; , , True: check-out
	If mVaultFile Is Nothing Then
		Logger.Error("Vault file search: File not found - Please double check that file can be found with search criteria applied.")
	Else
		Logger.Info("File " & mVaultFile & " found by search and downloaded to local workspace.")
		'add next action using the downloaded file here, e.g. Component.Replace("Part1:1", mVaultFile, True)
	End If
