07-04-2024
02:33 AM
- Mute
- Permalink
- Report
07-04-2024
02:33 AM
Oké see if we can debug this,
- We want to know if the Assy can be found, run this code a Message will appear.
Sub main ' Get the active assembly. Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim AssyName As String = "framework:1" 'name of the SubAssy Dim TemplateName As String = "white.dwg" 'name of the templae Dim Scale As String = "1:1" 'scale Dim SpacingBetweenViews As Double = 5 ' Call the function that does the recursion. TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, AssyName, TemplateName, Scale, SpacingBetweenViews) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, Name As String, TemplateName As String, scale As String, SpacingViews As Double) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject Dim DrawingTemplate As String = System.IO.Path.Combine(DesignProject.TemplatesPath, TemplateName) Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then If oOcc.Name = Name Then Dim AssyDoc As AssemblyDocument = oOcc.Definition.Document MsgBox("Assy Found" & " " & AssyDoc.FullFileName ) ' Dim oDrawDoc As DrawingDocument = CreateDrawing(DrawingTemplate) ' CreateViews(oDrawDoc, AssyDoc, scale, SpacingViews) End If TraverseAssembly(oOcc.SubOccurrences, Level + 1, Name, TemplateName, scale, SpacingViews) End If Next End Sub
