nstevelmans
in reply to: inventor4578
Hi, I think the problem was the position off the views, I have the code adjusted.
You can also adjust the spacing between the views.
If this answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
  Sub main
	  ' Get the active assembly.
        Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Dim AssyName As String = "framework:1"  'name of the SubAssy
        Dim TemplateName As String = "white.dwg"  'name of the templae
        Dim Scale As String = "1:1" 'scale
        Dim SpacingBetweenViews As Double = 5
        ' Call the function that does the recursion.
        TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, AssyName, TemplateName, Scale, SpacingBetweenViews)
  End Sub
    Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, Name As String, TemplateName As String, scale As String, SpacingViews As Double)
        ' Iterate through all of the occurrence in this collection.  This
        ' represents the occurrences at the top level of an assembly.
        Dim DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
        Dim DrawingTemplate As String = System.IO.Path.Combine(DesignProject.TemplatesPath, TemplateName)
        Dim oOcc As ComponentOccurrence
        For Each oOcc In Occurrences
            ' Check to see if this occurrence represents a subassembly
            ' and recursively call this function to traverse through it.
            If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                If oOcc.Name = Name Then
                    Dim AssyDoc As AssemblyDocument = oOcc.Definition.Document
                    Dim oDrawDoc As DrawingDocument = CreateDrawing(DrawingTemplate)
                    CreateViews(oDrawDoc, AssyDoc, scale, SpacingViews)
                End If
                TraverseAssembly(oOcc.SubOccurrences, Level + 1, Name, TemplateName, scale, SpacingViews)
            End If
        Next
    End Sub
    Private Function CreateDrawing(DrawingDoc As String) As DrawingDocument
        Dim result As DrawingDocument = Nothing
        Try
            Dim oNewDrawDoc As DrawingDocument = Nothing
            oNewDrawDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, DrawingDoc)
            result = oNewDrawDoc
        Catch ex As Exception
            MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateDrawing")
        End Try
        Return result
    End Function
    Private Sub CreateViews(ByVal oDrawDoc As DrawingDocument, ByVal oAssyDoc As AssemblyDocument, scale As String, SpacingViews As Double)
        Try
            'Set a reference to the active sheet.
            Dim oSheet As Sheet = oDrawDoc.ActiveSheet
            ' Create the placement point object.
            Dim Point1 As Double = ((oSheet.Width) / 2) - 8
            Dim Point2 As Double = ((oSheet.Height) / 2) - 6
            Dim oPoint As Point2d
            oPoint = ThisApplication.TransientGeometry.CreatePoint2d(Point1, Point2)
            'view 1 FrontView
            Dim oViewFront As DrawingView = CreateBaseView(oAssyDoc, oSheet, oPoint, True, "Front", ViewOrientationTypeEnum.kFrontViewOrientation)
            oViewFront.ScaleString = scale
            oViewFront.ViewStyle = DrawingViewStyleEnum.kShadedDrawingViewStyle
            Dim oBaseViewCenter As Point2d = oViewFront.Center
            Dim obaseViewX As Double = oBaseViewCenter.X
            Dim obaseViewY As Double = oBaseViewCenter.Y
            Dim ViewFrontheight As Double = oViewFront.Height
            Dim ViewFrontWidth As Double = oViewFront.Width
            Dim oViewTop = CreateProjectedView(oViewFront, oSheet, "Top", oViewFront.Center.Y + 10)
            Dim oViewSide = CreateProjectedView(oViewFront, oSheet, "Side",, oViewFront.Center.X + 10)
            Dim oViewIso = CreateProjectedView(oViewFront, oSheet, "Iso", oViewFront.Center.X + 10, oViewFront.Center.Y + 10)
            Dim ViewTopheight As Double = oViewTop.Height
            Dim ViewTopWidth As Double = oViewTop.Width
            Dim oViewTopPlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(obaseViewX, obaseViewY + (ViewFrontheight / 2) + (ViewTopheight / 2) + SpacingViews)
            oViewTop.Position = oViewTopPlace
            Dim ViewSideheight As Double = oViewSide.Height
            Dim ViewSideWidth As Double = oViewSide.Width
            Dim oViewSidePlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(obaseViewX + (ViewFrontWidth / 2) + (ViewSideWidth / 2) + SpacingViews, obaseViewY)
            oViewSide.Position = oViewSidePlace
            Dim ViewIsoheight As Double = oViewIso.Height
            Dim ViewIsoWidth As Double = oViewIso.Width
            Dim oViewIsoPlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oViewSide.Center.X + (ViewSideWidth / 2), oViewTop.Center.Y + (ViewTopheight / 2))
            oViewIso.Position = oViewIsoPlace
            MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateViews")
        End Try
    End Sub
    Private Function CreateBaseView(ByVal oAssyDoc As AssemblyDocument, oSheet As Sheet, oInsertionPoint2D As Point2d, Folded As Boolean, ByVal DrawingViewName As String, ByVal ViewOrientation As ViewOrientationTypeEnum) As DrawingView
        Dim result As DrawingView = Nothing
        Try
            ' Create a BaseView.
            Dim oBaseView As DrawingView
            oBaseView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oInsertionPoint2D, 1, ViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle)
            oBaseView.Name = DrawingViewName
            result = oBaseView
            MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateBaseView")
        End Try
        Return result
    End Function
    Private Function CreateProjectedView(ByVal baseView As DrawingView, sheet As Sheet, DrawingViewName As String, Optional height As Double = 0, Optional width As Double = 0) As DrawingView
        Try
            Dim oPositionBaseView As Point2d = baseView.Position
            Dim xBaseView As Double = oPositionBaseView.X
            Dim yBaseView As Double = oPositionBaseView.Y
            Dim oPointBottomView2 As Point2d
            oPointBottomView2 = ThisApplication.TransientGeometry.CreatePoint2d((xBaseView + width * 3), (yBaseView + height * 1.5))
            'BottomView
            Dim oProjected As DrawingView
            oProjected = sheet.DrawingViews.AddProjectedView(baseView, oPointBottomView2, DrawingViewStyleEnum.kShadedDrawingViewStyle)
            oProjected.Name = DrawingViewName
            result = oProjected
            MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateProjectedView")
        End Try
        Return result
    End Function
