Hi @harvey_craig2RCUH.  If you are referring to how we can use the blue, unquoted names of parameters within 'internal' iLogic rules (rules that are saved within Inventor documents), then nothing like that will work, because they will be seen as a String type object by the code processor, not as a Parameter.  However, you may be able to do something like:
Dim string1 As String = "my"
Dim string2 As String = "UserParameter"
Parameter(string1 & string2) = 42
But doing it this way will not cause the automatic triggering of the rule whenever its value changes.
Edit:  There is also the Inventor API way of getting that UserParameter, then setting its value, based on those two Strings, but its ModelValue & Value Properties Get/Set the value in 'database units' instead of 'document units' or 'parameter units'.
ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.Item(string1 & string2).Value = 42
Wesley Crihfield
(Not an Autodesk Employee)
