06-26-2024
01:38 PM
- Mute
- Permalink
- Report
06-26-2024
01:38 PM
Hi, try this code it has a recursive function so it will find every Occurrence in the assembly tree.
Sub main Dim CATEGORYVALUE As String = "ex.WELDMENT" ' Get the active assembly. Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oAssyCompdef As ComponentDefinition = oAsmDoc.ComponentDefinition Dim ViewRep As DesignViewRepresentation = SetDesignview(oAssyCompdef, CATEGORYVALUE) ' Call the function that does the recursion. TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, CATEGORYVALUE) ViewRep.Locked = True End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, PropValue As String) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence Dim value As String = Nothing For Each oOcc In Occurrences ' Print the name of the current occurrence. Dim oCompdef As ComponentDefinition = oOcc.Definition Dim oDoc As Document = oCompdef.Document Dim oCustomprop As Inventor.Property = Getproperty(oDoc, "CATEGORY") oOcc.Visible = False If oCustomprop IsNot Nothing Then If oCustomprop.Value = PropValue Then oOcc.Visible = True End If End If ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then TraverseAssembly(oOcc.SubOccurrences, Level + 1, PropValue) End If Next End Sub Private Function Getproperty(ByVal oDoc As Document, ByVal Prop As String) Dim result As Inventor.Property = Nothing Try Dim oPropertyset As PropertySet = oDoc.PropertySets("Inventor User Defined Properties") Dim oProperty As Inventor.Property = Nothing Try oProperty = oPropertyset.Item(Prop) Catch ex As Exception End Try result = oProperty Catch ex As Exception MsgBox(ex.ToString, MsgBoxStyle.Critical, "Getproperty") End Try Return result End Function Private Function SetDesignview(ByVal oAssyCompDef As AssemblyComponentDefinition, ViewRepName As String) As DesignViewRepresentation Dim result As DesignViewRepresentation = Nothing Dim ViewRep As DesignViewRepresentation = Nothing Dim ViewReps As DesignViewRepresentations = oAssyCompDef.RepresentationsManager.DesignViewRepresentations Try Dim ViewRepExist As Boolean = False For Each ViewRep In ViewReps If ViewRep.Name = ViewRepName Then ViewRep.Activate() ViewRepExist = True Exit For End If Next If ViewRepExist = False Then ViewRep = oAssyCompDef.RepresentationsManager.DesignViewRepresentations.Add(ViewRepName) ViewRep.Activate() End If Catch ex As Exception End Try result = ViewRep Return result End Function
