- Mute
- Permalink
- Report
Rule to create view reps
Hello All,
I have been working on this rule and it works for the most part. there is one spot that I am hung up on. I lost the links but this is concatenated from a bunch of previous posts on this forum. The rule is setup to:
-create view rep for each unique part in the assembly (filter out the phantom parts)
-scan each part for the custom iproperty "PART DESCRIPTION", if one exists then name the view rep that, if not then name the view rep the same as the part file name
-scan each part for the custom iproperty "CATEGORY", if the iprop exist, group the parts that share the same "CATEGORY" value (ex. WELDMENT), create and name the new view rep WELDMENT. there will be maybe 6 different "CATEGORY" groups eventually.
The first two sections work perfectly, and the third section partially works, the rule runs and creates the "CATEGORY" view rep, but there is only one visible part in the view rep, there should be more visible parts. I have tripled checked that the custom iprop does exist in the part files.
Any ideas? thanks!
' Define current document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim oTrans As Transaction
oTrans = ThisApplication.TransactionManager.StartTransaction(openDoc, "Create View Rep's")
On Error Goto ErrorHandler
' Set a reference to the assembly component definition.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Look at all of the components in the assembly
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = openDoc.ComponentDefinition
' Define the first level components collection
Dim oCompOcc As Inventor.ComponentOccurrence
' Define view rep
Dim oViewRep As DesignViewRepresentation
' Define an arraylist to hold the list of view rep names
Dim NameList As New Collection
' Look at the view reps in the assembly
For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations
' Set the list of names to the array list
NameList.Add (oViewRep.Name)
Next
' Check for a Default view rep and create it if not found
If Not NameList.Contains("FULL ASSEMBLY") Then
' Create Default view rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("FULL ASSEMBLY")
oViewRep.ShowAll
oViewRep.Activate
End If
' Zoom all
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
' Dictionary to store parts by category
Dim CategoryParts As Object
CategoryParts = CreateObject("Scripting.Dictionary")
' Look at all of the unique parts in the assembly
For Each docFile In openDoc.AllReferencedDocuments
If oCompDef.Occurrences.AllReferencedOccurrences(docFile).Count > 0 Then ' Avoid to create a view rep for base part of derived parts
If Not docFile.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then
If docFile.DocumentType = 12290 Then ' 12290 is the part document enumerator
' Locate the last backslash position in the full file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
' Remove path from part file name
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
' Remove extension from part file name
Dim ShortName As String
ShortName = Left(docFName, Len(docFName) - 4)
' Check for the custom iProperty "PART DESCRIPTION"
Dim partDescription As String
partDescription = ""
On Error Resume Next
partDescription = docFile.PropertySets.Item("Inventor User Defined Properties").Item("PART DESCRIPTION").Value
On Error Goto 0
' Determine view representation name
Dim viewRepName As String
If partDescription <> "" Then
viewRepName = partDescription
Else
viewRepName = ShortName
End If
' Check to see if the arraylist contains the desired view rep
If Not NameList.Contains(viewRepName) Then
' Create new View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(viewRepName)
oViewRep.Activate
oViewRep.Locked = False
Else
' Reference existing View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(viewRepName)
oViewRep.Activate
End If
Dim bSkip As Boolean
bSkip = False
' Look at all of the occurrences
For Each oCompOcc In oCompDef.Occurrences.AllLeafOccurrences
' Locate the colon position in the occurrence name
Dim oCompOccPos As Long
oCompOccPos = InStrRev(oCompOcc.Name, ":")
If oCompOccPos < 2 Then oCompOccPos = Len(oCompOcc.Name)
' Set occurrence name to everything left of the colon
Dim oOccName As String
oOccName = Left(oCompOcc.Name, oCompOccPos - 1)
' Set visible if name matches first occurrence
If System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName) = ShortName And bSkip = False Then
oCompOcc.Visible = True
ThisApplication.ActiveView.Update
bSkip = True ' Even if there is more than one occurrence named "xyz:1" in different sub-assemblies, we want only one occurrence in our view rep
Else
oCompOcc.Visible = False
End If
Next
' Lock view rep
oViewRep.Locked = True
' Check for the custom iProperty "CATEGORY"
Dim category As String
category = ""
category = docFile.PropertySets.Item("Inventor User Defined Properties").Item("CATEGORY").Value
On Error Goto 0
' Add part to the corresponding category list
If category <> "" Then
If Not CategoryParts.Exists(category) Then
CategoryParts.Add (category, New Collection)
End If
CategoryParts(category).Add (docFile)
End If
End If
End If
End If
Next
' Create view representations for each category
For Each category In CategoryParts.Keys
If Not NameList.Contains(category) Then
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(category)
oViewRep.Activate
Else
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(category)
oViewRep.Activate
End If
' Set visibility for parts in the category
For Each docFile In CategoryParts(category)
bSkip = False
If System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName) = _
System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName) And bSkip = False Then
Else
End If
Next
Next
' Lock view rep
Next
' Set Default View Rep active
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("FULL ASSEMBLY").Activate
oTrans.End
Exit Sub
ErrorHandler:
MsgBox (Err.Description)
oTrans.Abort
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
