- Mute
- Permalink
- Report
Rule to create view reps
Hello All,
I have been working on this rule and it works for the most part. there is one spot that I am hung up on. I lost the links but this is concatenated from a bunch of previous posts on this forum. The rule is setup to:
-create view rep for each unique part in the assembly (filter out the phantom parts)
-scan each part for the custom iproperty "PART DESCRIPTION", if one exists then name the view rep that, if not then name the view rep the same as the part file name
-scan each part for the custom iproperty "CATEGORY", if the iprop exist, group the parts that share the same "CATEGORY" value (ex. WELDMENT), create and name the new view rep WELDMENT. there will be maybe 6 different "CATEGORY" groups eventually.
The first two sections work perfectly, and the third section partially works, the rule runs and creates the "CATEGORY" view rep, but there is only one visible part in the view rep, there should be more visible parts. I have tripled checked that the custom iprop does exist in the part files.
Any ideas? thanks!
' Define current document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim oTrans As Transaction
oTrans = ThisApplication.TransactionManager.StartTransaction(openDoc, "Create View Rep's")
On Error Goto ErrorHandler
' Set a reference to the assembly component definition.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Look at all of the components in the assembly
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = openDoc.ComponentDefinition
' Define the first level components collection
Dim oCompOcc As Inventor.ComponentOccurrence
' Define view rep
Dim oViewRep As DesignViewRepresentation
' Define an arraylist to hold the list of view rep names
Dim NameList As New Collection
' Look at the view reps in the assembly
For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations
' Set the list of names to the array list
NameList.Add (oViewRep.Name)
Next
' Check for a Default view rep and create it if not found
If Not NameList.Contains("FULL ASSEMBLY") Then
' Create Default view rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("FULL ASSEMBLY")
oViewRep.ShowAll
oViewRep.Activate
End If
' Zoom all
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
' Dictionary to store parts by category
Dim CategoryParts As Object
CategoryParts = CreateObject("Scripting.Dictionary")
' Look at all of the unique parts in the assembly
For Each docFile In openDoc.AllReferencedDocuments
If oCompDef.Occurrences.AllReferencedOccurrences(docFile).Count > 0 Then ' Avoid to create a view rep for base part of derived parts
If Not docFile.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then
If docFile.DocumentType = 12290 Then ' 12290 is the part document enumerator
' Locate the last backslash position in the full file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
' Remove path from part file name
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
' Remove extension from part file name
Dim ShortName As String
ShortName = Left(docFName, Len(docFName) - 4)
' Check for the custom iProperty "PART DESCRIPTION"
Dim partDescription As String
partDescription = ""
On Error Resume Next
partDescription = docFile.PropertySets.Item("Inventor User Defined Properties").Item("PART DESCRIPTION").Value
On Error Goto 0
' Determine view representation name
Dim viewRepName As String
If partDescription <> "" Then
viewRepName = partDescription
Else
viewRepName = ShortName
End If
' Check to see if the arraylist contains the desired view rep
If Not NameList.Contains(viewRepName) Then
' Create new View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(viewRepName)
oViewRep.Activate
oViewRep.Locked = False
Else
' Reference existing View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(viewRepName)
oViewRep.Activate
End If
Dim bSkip As Boolean
bSkip = False
' Look at all of the occurrences
For Each oCompOcc In oCompDef.Occurrences.AllLeafOccurrences
' Locate the colon position in the occurrence name
Dim oCompOccPos As Long
oCompOccPos = InStrRev(oCompOcc.Name, ":")
If oCompOccPos < 2 Then oCompOccPos = Len(oCompOcc.Name)
' Set occurrence name to everything left of the colon
Dim oOccName As String
oOccName = Left(oCompOcc.Name, oCompOccPos - 1)
' Set visible if name matches first occurrence
If System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName) = ShortName And bSkip = False Then
oCompOcc.Visible = True
ThisApplication.ActiveView.Update
bSkip = True ' Even if there is more than one occurrence named "xyz:1" in different sub-assemblies, we want only one occurrence in our view rep
Else
oCompOcc.Visible = False
End If
Next
' Lock view rep
oViewRep.Locked = True
' Check for the custom iProperty "CATEGORY"
Dim category As String
category = ""
category = docFile.PropertySets.Item("Inventor User Defined Properties").Item("CATEGORY").Value
On Error Goto 0
' Add part to the corresponding category list
If category <> "" Then
If Not CategoryParts.Exists(category) Then
CategoryParts.Add (category, New Collection)
End If
CategoryParts(category).Add (docFile)
End If
End If
End If
End If
Next
' Create view representations for each category
For Each category In CategoryParts.Keys
If Not NameList.Contains(category) Then
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(category)
oViewRep.Activate
Else
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(category)
oViewRep.Activate
End If
' Set visibility for parts in the category
For Each docFile In CategoryParts(category)
bSkip = False
If System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName) = _
System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName) And bSkip = False Then
Else
End If
Next
Next
' Lock view rep
Next
' Set Default View Rep active
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("FULL ASSEMBLY").Activate
oTrans.End
Exit Sub
ErrorHandler:
MsgBox (Err.Description)
oTrans.Abort
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
- Mute
- Permalink
- Report
Hi @Shag_Bore
I quickly reviewed the code and couldn't really see the issue, so I can only offer a little advice having done this process before.
- If you have narrowed your problem area set up some logger statements and check the occurrence name is being logically reached based on needing to be visible or not.
- I would suggest to use Try Catch Statements over On Error Resume Next. You really have no indication of what is happening with the On Error methods.
- I see two leaf occurrences loops are they both needed or could you put it in a function or to store the occurrences as a list of occurrences?
- i see you create weekly typed Collections rather than to explicitly declare the type. Example for string. this can help narrow down issues if the wrong object type gets added into the collection.
Dim list as New List (Of String)
Dim occList as New List (Of ComponentOccurrence)
- If this section of code is designed to get the filename without extension then I would suggest to change it to System IO method as it has less lines. The method here looks more like old VBA methods.
You actually use it further down the code.
ShortName = System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName)
- In this section there is a good lot of code duplication with the same definition variables used in different places all the way through the code. It will work but it could lead to issues identifying what is going on especially when trying to target sub assemblies etc.
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
Hi, try this code it has a recursive function so it will find every Occurrence in the assembly tree.
Sub main Dim CATEGORYVALUE As String = "ex.WELDMENT" ' Get the active assembly. Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oAssyCompdef As ComponentDefinition = oAsmDoc.ComponentDefinition Dim ViewRep As DesignViewRepresentation = SetDesignview(oAssyCompdef, CATEGORYVALUE) ' Call the function that does the recursion. TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, CATEGORYVALUE) ViewRep.Locked = True End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, PropValue As String) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence Dim value As String = Nothing For Each oOcc In Occurrences ' Print the name of the current occurrence. Dim oCompdef As ComponentDefinition = oOcc.Definition Dim oDoc As Document = oCompdef.Document Dim oCustomprop As Inventor.Property = Getproperty(oDoc, "CATEGORY") oOcc.Visible = False If oCustomprop IsNot Nothing Then If oCustomprop.Value = PropValue Then oOcc.Visible = True End If End If ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then TraverseAssembly(oOcc.SubOccurrences, Level + 1, PropValue) End If Next End Sub Private Function Getproperty(ByVal oDoc As Document, ByVal Prop As String) Dim result As Inventor.Property = Nothing Try Dim oPropertyset As PropertySet = oDoc.PropertySets("Inventor User Defined Properties") Dim oProperty As Inventor.Property = Nothing Try oProperty = oPropertyset.Item(Prop) Catch ex As Exception End Try result = oProperty Catch ex As Exception MsgBox(ex.ToString, MsgBoxStyle.Critical, "Getproperty") End Try Return result End Function Private Function SetDesignview(ByVal oAssyCompDef As AssemblyComponentDefinition, ViewRepName As String) As DesignViewRepresentation Dim result As DesignViewRepresentation = Nothing Dim ViewRep As DesignViewRepresentation = Nothing Dim ViewReps As DesignViewRepresentations = oAssyCompDef.RepresentationsManager.DesignViewRepresentations Try Dim ViewRepExist As Boolean = False For Each ViewRep In ViewReps If ViewRep.Name = ViewRepName Then ViewRep.Activate() ViewRepExist = True Exit For End If Next If ViewRepExist = False Then ViewRep = oAssyCompDef.RepresentationsManager.DesignViewRepresentations.Add(ViewRepName) ViewRep.Activate() End If Catch ex As Exception End Try result = ViewRep Return result End Function
