MechMachineMan
in reply to: Skanda_UNI
I don't think so. I tried running it in 2018.2 and got no compiler errors or issues came up aside from the fact I ran it from a blank which caused an error. It makes me think it it is dataset specific.
Also, you can't "Unmark" things as a solution. It is helpful to add relevant questions to the same thread, but if you get no responses, it doesn't hurt to start a new thread.
What I would do in your case is try to manually debug it and isolate what line the error occurs at. It my signature (below this text) is a link on how to "manually debug" in iLogic. Report back when you've done that.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
