Skanda_UNI
in reply to: Skanda_UNI
Hello!
i tried a few things and looked up a view solutions
https://forums.autodesk.com/t5/inventor-customization/inventor-2018-ilogic-error/td-p/7073741
implemented - not working
https://www.aplicit.com/erreur-ilogic-exception/
https://developercommunity.visualstudio.com/content/problem/32072/invalid-pointer-exception-from-hre...
here it says i can fix this by repairing the visual studio installation (???)
https://forums.autodesk.com/t5/inventor-customization/ilogic-made-pdf-w-rev/td-p/7154650
implemented that, but it did not work out
It all says that the problem is in the PDFAddIn section. And as the error message appears when the top level drawing is opened i assume that the problem is there. For me it just trial and error.
SyntaxEditor Code Snippet
oAsmDrawing = ThisDoc.ChangeExtension(".idw")
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -4)
'write out the PDF for the Top Level Assembly Drawing file' if PDF exists and is open or read only, resume next
 'Set the PDF target file name'oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & ".pdf"
oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "_v" & Microsoft.VisualBasic.Strings.Format(oAsmDrawingDoc.FileSaveCounter,"00#") & ".pdf"
'Write out the PDF'PDFAddIn = ThisApplication.Documents.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")'PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Close the top level drawing
oAsmDrawingDoc.Close
unfortunately i guess my programming skills are not sufficient to solve this problem.
Maybe you could give me hint, what to do.
thank you
