josh.nieman
101 Views, 0 Replies
DrawingView.ReferenceDataDisplayStyle does not appear functional or present on DrawingView objects.
Refer to: https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=DrawingView_ReferenceDataDisplayStyle
and https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=ReferenceDataDisplayStyleEnum
This appears to be a read/write value on Inventor.DrawingView objects, which should enable access to set the display options for Reference Data from the model.
I get a a COMException error when trying to access this property of an Inventor.DrawingView object in memory:
Exception thrown: 'System.Runtime.InteropServices.COMException' in mscorlib.dll
System.Transactions Critical: 0 :
<Exception>
     <ExceptionType>System.Runtime.InteropServices.COMException, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</ExceptionType>
     <Message>Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))</Message>
at Inventor.DrawingView.get_ReferenceDataDisplayStyle()
<Exception>
Also, when the code breaks, and I use the Dynamic View in Visual Studio 2022, this property is not among the many identified for this object.
Has anyone gotten this to work?
Currently running Inventor 2024.3 and my application references version 28.2 of the interop.dll
