mat_hijs
256 Views, 2 Replies
Transformation of coordinates
Quite some time ago I wrote some code that reads coordinates from an excel file like the one below and places the specified components at these coordinates.
This works fine, but I want to expand on this a little bit. I want to add the option to specify an overall transformation for all these coordinates. For example I may want to place the components in the screenshot above, but instead of them all being on the XY Plane and the first one being on 0, 0, 0 I want to have everything rotated 45 degrees around the Y Axis and the first one to be placed on 10, 10, 10.
Basically I want to place all the components and then move/rotate everything to another coordinate system.
I'm not too familiar with the whole matrix thing so I'm not sure how to start this.
Here's the code to place the components and move them so a specific workpoint in the component is on the given coordinate. This does not include the part that reads the data from excel.
Sub Main
	Dim oOcc As ComponentOccurrence = PlaceOccurrence("C:\Users\mathi\OneDrive\Documenten\Inventor Addin Development\Test Excel\Test Part Grijs.ipt", 0, 0, 0, 0, 0, 0)
	MoveOccurrenceToInsertionPoint(oOcc, "Center Point")
End Sub
Public Function PlaceOccurrence(ByVal sFilePath As String, ByVal Location_X As Double, ByVal Location_Y As Double, ByVal Location_Z As Double, ByVal Rotation_X As Double, ByVal Rotation_Y As Double, ByVal Rotation_Z As Double, Optional ByVal bGrounded As Boolean = True) As ComponentOccurrence
	Dim oResult As ComponentOccurrence
	' Set a reference to the Assembly Document
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	' Set a reference to the Assembly Component Definition
	Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	' Set a reference to the Transient Geometry
	Dim oTransientGeometry As TransientGeometry = ThisApplication.TransientGeometry
	' Create Matrices
	Dim oMatrix As Matrix = oTransientGeometry.CreateMatrix
	Dim oMatrix_Z As Matrix = oTransientGeometry.CreateMatrix
	Dim oMatrix_Y As Matrix = oTransientGeometry.CreateMatrix
	Dim oMatrix_X As Matrix = oTransientGeometry.CreateMatrix
	' Set the rotation of the Matrix about the Z axis
	oMatrix_Z.SetToRotation(Rotation_Z * (Math.PI / 180), oTransientGeometry.CreateVector(0, 0, 1), oTransientGeometry.CreatePoint(0, 0, 0))
	' Set the rotation of the Matrix about the Y axis
	oMatrix_Y.SetToRotation(Rotation_Y * (Math.PI / 180), oTransientGeometry.CreateVector(0, 1, 0), oTransientGeometry.CreatePoint(0, 0, 0))
	' Set the rotation of the Matrix about the X axis
	oMatrix_X.SetToRotation(Rotation_X * (Math.PI / 180), oTransientGeometry.CreateVector(1, 0, 0), oTransientGeometry.CreatePoint(0, 0, 0))
	' PreMultiply the Matrix by the Matrices about each axis
	oMatrix.PreMultiplyBy(oMatrix_Z)
	oMatrix.PreMultiplyBy(oMatrix_Y)
	oMatrix.PreMultiplyBy(oMatrix_X)
	' Set the Translation of the matrix
	oMatrix.SetTranslation(oTransientGeometry.CreateVector(Location_X / 10, Location_Y / 10, Location_Z / 10))
	' Set a reference to the Component Occurrences
	Dim oOccurrences As ComponentOccurrences = oAsmCompDef.Occurrences
	' Place a Component Occurrence
	Dim oOcc As ComponentOccurrence = oOccurrences.Add(sFilePath, oMatrix)
	' Ground the Component Occurrence
	oOcc.Grounded = bGrounded
	' Return the Component Occurrence
	oResult = oOcc
	Return oResult
End Function
Public Function MoveOccurrenceToInsertionPoint(ByVal oOcc As ComponentOccurrence, ByVal sWorkPointName As String) As ComponentOccurrence
	' Set a reference to the Document of the Component Occurrence
	Dim oOccDoc As Document = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
	' Get the Origin Point WorkPoint
	Dim oWPoint_Origin_Point As WorkPoint = oOccDoc.ComponentDefinition.WorkPoints.Item(1)
	' Create a Proxy of the Origin Point WorkPoint
	Dim oWPoint_Origin_Point_Proxy As WorkPointProxy = Nothing
	oOcc.CreateGeometryProxy(oWPoint_Origin_Point, oWPoint_Origin_Point_Proxy)
	' Check if the Occurrence should be moved to a WorkPoint other than the Origin Point WorkPoint
	If sWorkPointName <> "" AndAlso sWorkPointName <> "Center Point" Then
		Try
			' Get the Insertion Point WorkPoint
			Dim oWPoint_Insertion_Point As WorkPoint = oOccDoc.ComponentDefinition.WorkPoints.Item(sWorkPointName)
			' Create a Proxy of the Insertion Point WorkPoint
			Dim oWPoint_Insertion_Point_Proxy As WorkPointProxy = Nothing
			oOcc.CreateGeometryProxy(oWPoint_Insertion_Point, oWPoint_Insertion_Point_Proxy)
			' Get the translation between the two WorkPoints
			Dim dTranslation_X As Double = oWPoint_Origin_Point_Proxy.Point.X - oWPoint_Insertion_Point_Proxy.Point.X
			Dim dTranslation_Y As Double = oWPoint_Origin_Point_Proxy.Point.Y - oWPoint_Insertion_Point_Proxy.Point.Y
			Dim dTranslation_Z As Double = oWPoint_Origin_Point_Proxy.Point.Z - oWPoint_Insertion_Point_Proxy.Point.Z
			' Set the translation Matrix
			Dim oTranslatedMatrix As Matrix = oOcc.Transformation
			oTranslatedMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(oWPoint_Origin_Point_Proxy.Point.X + dTranslation_X, oWPoint_Origin_Point_Proxy.Point.Y + dTranslation_Y, oWPoint_Origin_Point_Proxy.Point.Z + dTranslation_Z))
			' Set the transformation of the Component Occurrence
			oOcc.Transformation = oTranslatedMatrix
		Catch
			MsgBox("Work Point """ & sWorkPointName & """ was not found, the Occurrence was placed using the Origin Point")
		End Try
	End If
	oResult = oOcc
	Return oResult
End Function
Michael.Navara
in reply to: mat_hijs
The easiest way is to define your UCS in assembly and use its transformation to move the component. Below is the relevant part of your code. Everything else stay unchanged.
' Transform matrix to UCS1
Dim oUcsMatrix As Matrix = oAsmCompDef.UserCoordinateSystems("UCS1").Transformation
oMatrix.PostMultiplyBy(oUcsMatrix)
mat_hijs
in reply to: Michael.Navara
This did not give me the exact result I was expecting, it gave it the correct rotation, but the distances between components were in the directions of the assembly origin, not the UCS. However when I use PreMultiplyBy instead of PostMultiplyBy it gives me the desired result.
After I got this working I decided not to go with using a UCS at all but instead just created the matrix that I'd have to create for the definition of the UCS anyway and use this directly for the PreMultiplyBy.
Here's my final code (not iLogic):
Public Shared Function PlaceOccurrence(ByVal sFilePath As String, ByVal Location_X As Double, ByVal Location_Y As Double, ByVal Location_Z As Double, ByVal Rotation_X As Double, ByVal Rotation_Y As Double, ByVal Rotation_Z As Double, ByVal Base_Location_X As Double, ByVal Base_Location_Y As Double, ByVal Base_Location_Z As Double, ByVal Base_Rotation_X As Double, ByVal Base_Rotation_Y As Double, ByVal Base_Rotation_Z As Double, Optional ByVal bGrounded As Boolean = True) As ComponentOccurrence
	Dim oAsmDoc As AssemblyDocument = g_inventorApplication.ActiveDocument
	' Create a Matrix
	Dim oOccMatrix As Matrix = MS_Matrices.CreateMatrixFromLocationAndRotation(Location_X, Location_Y, Location_Z, Rotation_X, Rotation_Y, Rotation_Z)
	' Create a Matrix
	Dim oBaseMatrix As Matrix = MS_Matrices.CreateMatrixFromLocationAndRotation(Base_Location_X, Base_Location_Y, Base_Location_Z, Base_Rotation_X, Base_Rotation_Y, Base_Rotation_Z)
	' PreMultiply the Occurrence Matrix by the Base Matrix
	oOccMatrix.PreMultiplyBy(oBaseMatrix)
	Dim oOcc As ComponentOccurrence = oOccurrences.Add(sFilePath, oOccMatrix)
	' Set the Default View Representation if the Component Occurrence is an Assembly
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oOcc.SetDesignViewRepresentation("Default", , True)
	oResult = oOcc
	Return oResult
End Function
Public Shared Function CreateMatrixFromLocationAndRotation(ByVal Location_X As Double, ByVal Location_Y As Double, ByVal Location_Z As Double, ByVal Rotation_X As Double, ByVal Rotation_Y As Double, ByVal Rotation_Z As Double) As Matrix
	Dim oResult As Matrix
	Dim oTransientGeometry As TransientGeometry = g_inventorApplication.TransientGeometry
	' Create Matrices
	oResult = oMatrix
	Return oResult
End Function
