dhanshri_gavas
212 Views, 1 Reply
Inventor model tree structure
I have an assembly document open. In that assembly document, I've added a subassembly (using the default template). Now, within that subassembly, I want to import a STEP file or add another subassembly. However, currently, the imported part or subassembly is added to the main assembly. How can I add a part or assembly inside the subassembly using the API?
now it is looking like this
I want structure like this
Thanks in advance!
WCrihfield
in reply to: dhanshri_gavas
If you want to insert sub assemblies or imported models under a sub assembly, then you must open that sub assembly directly, then insert them directly within that document.  You can not do it remotely from a higher level assembly.
Wesley Crihfield
(Not an Autodesk Employee)
