kv5053545
203 Views, 2 Replies
Material Library
I have a question is it possible to enter from code to the library of materials and get all the names of the materials?
Frederick_Law
in reply to: kv5053545
Could you give the library path?
Arthur Knoors
Autodesk Affiliations:
