05-24-2024
01:22 AM
- Mute
- Permalink
- Report
05-24-2024
01:22 AM
I'm using a code that I activate when I want to make a pdf
The code creates two pdf's. One on a specific location in our network and one in the folder where the IDW is. In that folder a new folder is made "PDF" and the folder will also open automatically after the pdf has been created
Here's the code:
On Error Resume Next 'define the folder where you want to save the files oFolder = "g:\pdf\2024\" 'grab the filename oFileName = ThisDoc.FileName(False) 'without extension 'create the folder if it doesn't exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'save as a pdf ThisDoc.Document.SaveAs(oFolder & oFileName & - 1 & ".pdf", True) oPath = ThisDoc.Path 'get STEP target folder path oFolder = oPath & "\" & oAsmName & " PDF" 'Check for the step folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If ThisDoc.Document.SaveAs(oFolder & "\" & oFileName & " - 1" &(".pdf"), True) 'open the folder where the new files are saved Shell("explorer.exe " & oFolder,vbNormalFocus)
