05-22-2024
09:50 PM
- Mute
- Permalink
- Report
05-22-2024
09:50 PM
@Michael.Navara wrote:The code snippet can be modified to change appearance of SurfaceBodyProxy at the assembly level.
If you want to add content of appearance library it is easy but you need to ensure the selected appearance to copy to the document before you assign them to the body.
See Set the appearance of an occurrence API Sample for more information.
Sorry, I am new to iLogic.
Have looked your link to HELP but have no idea how to make it works.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
