@mat_hijs
It just occurred to me that "Components.AddContentCenterPart" is an iLogic function, and not an API function, and so maybe you would need to use the API to place the CC part in this case? Or maybe add a reference to the iLogic Add-in?
I'm just making guesses about that though, it's been a while since I've uses classes in this way with iLogic, so I forget the particulars. In any case I'm not sure I understand why the internal rule vs external rule situation would arise in this case, but maybe it's something to think about?
API example:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-57915C88-FF59-4ED6-9A67-47E55DD62639
I hope this helps.
Curtis
