05-21-2024
02:32 AM
- Mute
- Permalink
- Report
05-21-2024
02:32 AM
The code snippet can be modified to change appearance of SurfaceBodyProxy at the assembly level.
If you want to add content of appearance library it is easy but you need to ensure the selected appearance to copy to the document before you assign them to the body.
See Set the appearance of an occurrence API Sample for more information.
Sub Main()
Dim bodyProxy As SurfaceBodyProxy
Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Pick a body")
Dim surfaceBodyProxy As SurfaceBodyProxy = TryCast(pick, SurfaceBodyProxy)
If Not surfaceBodyProxy Is Nothing Then
bodyProxy = surfaceBodyProxy
Else
Return
End If
ChangeAppearance(bodyProxy)
ThisApplication.ActiveDocument.Update()
End Sub
Private Sub ChangeAppearance(bodyProxy As SurfaceBodyProxy)
Dim asmDef As AssemblyComponentDefinition = bodyProxy.ContainingOccurrence.ContextDefinition
Dim asmDoc As AssemblyDocument = asmDef.Document
Dim assetNames = asmDoc.AppearanceAssets.OfType(Of Asset).Select(Function(x) x.DisplayName)
Dim selectedAssetName As String = InputListBox("Select Appearance", assetNames).ToString()
Dim selectedAsset As Asset = asmDoc.AppearanceAssets.OfType(Of Asset).FirstOrDefault(Function(x) x.DisplayName = selectedAssetName)
If selectedAsset Is Nothing Then Return
bodyProxy.Appearance = selectedAsset
End Sub
