BeKirra
in reply to: Michael.Navara
Sorry, for the late response.
And thanks for your help.
Can the code not modify the part file when changing the appearance?
I'd like keep the part file or sub-assembly as it is.
Also, can "Inventor Material Library" be available in the list box?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
