A.Acheson
in reply to: harland.jU5ZCW
The easiest method would be to use the ilogic API and the capture tool n the editor.
Go to your part in the ilogic model browser right click and component add. This will process the code needed to add this specific occurrence. Use this as a guide only as you might not want to add this part on its own.
In the ilogic snippet  browser you should find a function for content center replace of a component. This should allow you to replace one component for another and even allow multiple replacements within the sub assembly.
Actually replacing all parts in all sub assemblies will be a little more difficult as you will need to dip into the Inventor API to start working with all the occurrence. See VBA sample of replacing one part manually picked.
I would suggest to work first with the ilogic API and just get a replacement of one part to happen. Then work from there. Post any code your having difficulty with.
Regards
Alan
