ward_hanotGZU45
367 Views, 2 Replies
Automatic partname renaming after copy in rules
Hello Inventor people,
I starting on the iLogic adventure and I have encounterd my first problem.
I have created an assembly with 3 parts: Cabine, Dak, Vloer. The assembly is called LUX-Cabine.
I created a form witch handels a couple of parameters. They all work well and ass intended.
Now I want this assemblie be copied because I want to use it for making fast customer drawings.
For Customers we have a specifiek namescheme: 2024-XXXX, where X is the number of the project but it does go up normaly because of internal reasons.
I copied it using ilogic copy design and design assitant. But the rules don't work anymore because the refrence to the Cabine part and not to the new 2024-XXXX-Cabine.
Example:
Feature.IsActive("Cabine-Start:1", "Z1DOE") = DeurZicht1
 Cabine-Start should become 2024-XXXX-Cabine.
Is there a way to either change the rule so that it matches the current partname or another workaround so that the form is useble.
I would prefer to renem the parts to the project. I would not like to have a 100 parts all names Cabine acrose several folders.
Thanks in advance
