05-06-2024
04:36 AM
- Mute
- Permalink
- Report
05-06-2024
04:36 AM
Hi @b.mccarthy. Yes, that should not be much trouble. However, it is a typical Monday morning for me at work, so there are a few things I need to catch up on after having the weekend off, so I will report back later today, hopefully with the updated code example. The main thing that will need to happen is transferring the block of code that will get repeated many times down into a separate Sub routine, while keeping the custom stuff that only needs to be specified once up in the 'Main' routine, or between routines.
Wesley Crihfield
(Not an Autodesk Employee)
