A.Acheson
in reply to: xenocatalyst
Hi @xenocatalyst
If you check the face surface type to ensure it's a plane surface then you should be home and dry. The sample API help page shown here in face.geometry gave me the hint for this
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPlane1 As Plane = Nothing
Dim oPlane2 As Plane = Nothing
Dim oFaces As Faces = oDoc.ComponentDefinition.SurfaceBodies.Item(1).Faces 'gets too many results but works, using worksurfaces doesnt give me the correct result
MessageBox.Show(oFaces.Count.ToString, "Check No. of faces in Surface body")
Dim oFace1 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select a face")
Dim oFace2 As Face = Nothing
oPlane1 = oFace1.Geometry
For Each oFace As Face In oFaces
	 If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
		If oPlane1.IsCoplanarTo(oFace.Geometry) Then
		ElseIf oPlane1.IsParallelTo(oFace.Geometry) Then
				oFace2 = oFace
		End If
    End If
Next
DistPoints = ThisApplication.MeasureTools.GetMinimumDistance(oFace1, oFace2)
Distmm = Round(DistPoints * 10).ToString() + "mm Thick"
MessageBox.Show(Distmm, "Title")
Regards
Alan
