05-01-2024
11:10 AM
- Mute
- Permalink
- Report
05-01-2024
11:10 AM
Hi @DME_Ltd. I have a couple suggestions for you to check out, but not sure if this is the issue or not.
This sounds a little bit like it might be what I suspect, but I am not sure.
Try these things in a new, empty iLogic rule, then tell me if they help any:
- Type in "System", then the dot after it.
- At the bottom of that 'suggestions' list, do you see two icons...one for 'Types' and one for 'Namespaces'?
- If so, those are filters, so make sure both are active.
- After "System.", choose "Windows", then "Forms", then "AxHost".
- Type the dot after AxHost, and you should see a different 'filter' icon...one for 'Type Members'.
- If so, make sure that one is turned on also.
Wesley Crihfield
(Not an Autodesk Employee)
