' Get the current drawing document
Dim doc As DrawingDocument = ThisDoc.Document
' Loop through all the sheets in the drawing
For Each sheet As Sheet In doc.Sheets
    ' Get the first view on the sheet
    Dim view As DrawingView = Sheet.DrawingViews.Item(1)
    ' Check if the view exists
    If Not view Is Nothing Then
        ' Print the name of the sheet being checked
        Debug.Print("Checking sheet: " & Sheet.Name)
        ' Get the associated model
        Dim model As Document = view.ReferencedDocumentDescriptor.ReferencedDocument
        ' Check if the model exists and has the desired iProperty
        If Not model Is Nothing Then
            Try
                ' Get the value of the desired iProperty (replace "CustomProperty" with your actual iProperty name)
                Dim customPropertyValue As String = model.PropertySets.Item("Inventor Summary Information").Item("Panel ID").Value
                ' Output the value of the iProperty
                MsgBox("The value of the custom property is: " & customPropertyValue & vbCrLf & "Checked on sheet: " & Sheet.Name)
            Catch ex As Exception
                ' Handle the case where the property doesn't exist
                ' You can add your custom error handling here
                MsgBox("The desired iProperty does not exist in the model.")
            End Try
        End If
    End If
Next
