WCrihfield
in reply to: davidt162003
Hi @davidt162003.  You did not post the code that you were trying to use for this task, and did not attach the part file itself for us to test on, so it would be very difficult for us to help determine why that code is having trouble doing its task on that one specific part.  Nothing about the image seems to show any reason for the problem.  Is it possible that the part is ReadOnly, for one reason or another?  If the part was from the Content Center, or its file is located in an area designated as a Library, those could cause the part to act like ReadOnly.  Also, if accessing that part from an assembly, and it had multiple ModelStates in it, and there were more than one of them in the assembly, it may be understanding that assembly component as being a 'member' ModelState, which could be treated as ReadOnly.
Wesley Crihfield
(Not an Autodesk Employee)
