davidt162003
297 Views, 2 Replies
Cant add a work point to specific part/parts
so i have a series of parametric parts which i then update using the api and within that update i add a work point on to them typically using this code
However as seen in the screen shot its starting throwing a error for just a single type part.
 this is the part in question.
If i had to guess the error either occurs because I'm trying to add in the work point before the update is complete(parameters changed but model isn't updated) or because of something to do with the base part file I'm copying it from.
HII
Tags (2)
Labels (2)
