Hi @vpeuvion
The native object of the parent of the parent should provide you the correct object.
I just realized this wasn't returning what I thought it was... I'll try and have another look later
update: see version below that uses the ParentOccurrence of the parent.parent
Sub Main
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Face")
	If oFace Is Nothing Then Exit Sub
	If TypeOf oFace.Parent.Parent Is ComponentOccurrenceProxy Then
		MessageBox.Show(oFace.Parent.Parent.ParentOccurrence.name)
	ElseIf TypeOf oFace.Parent.Parent Is ComponentOccurrence
		MessageBox.Show(oFace.Parent.Parent.Parent.Document.Displayname )
	End If
End Sub
 I hope this helps.
Curtis
