04-23-2024
02:57 AM
- Mute
- Permalink
- Report
04-23-2024
02:57 AM
Hi @karram
What does the code in the part files do?
Most likely you can move that code up to an assembly rule and run it on each occurrence, and eliminate the need to run rules down at the part level.
For example if the rule were suppressing a hole in the parts, you could have something like this at the assembly level to do the same thing
Dim oDoc As AssemblyDocument = ThisDoc.Document For Each oOcc In oDoc.ComponentDefinition.Occurrences Try Feature.IsActive(oOcc.name, "Hole2") = False Catch ex As Exception Logger.Error(ex.Message) End Try Next
I hope this helps.
Curtis
