jzarczynski
207 Views, 2 Replies
Cut Feature Depth in sheet metal
There is no property like Depth for CutFeature Object.
In holes i colect the depth by:
Dim holeDepth As Double = hole.Depth
How to check the depth of Cutfeature ? Could you please present the approach?
My goal is to identify all blind holes in sheet metal, including the ones made by "cut" function,
BM_Ashraf
in reply to: jzarczynski
Hope this script helps you in moving forward!
	Dim oDoc As PartDocument = ThisDoc.Document
	Dim oCutFeature As CutFeature
	Try
		oCutFeature = ThisApplication.CommandManager.Pick(kPartFeatureFilter, "Please select The Cut feature")
	Catch
		Exit Sub
	End Try
	If oCutFeature.Definition.ExtentType = kDistanceExtent Then
	  Dim oExtent As DistanceExtent = oCutFeature.Definition.Extent
	  Dim oDistance As ModelParameter = oExtent.Distance
	    MsgBox (oDistance.Value * 10)
	End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
jzarczynski
