chris
425 Views, 2 Replies
iLogic code to change a drawings sheet "name"...
I was wondering if someone could write an iLogic code that would rename a drawing sheet name to match the file name of the part detailed on that sheet. In this case, there would only be one part per sheet, ( no multiple parts per sheet), however, the first few sheets might have assembly views. so the code would need to only rename sheets that has parts only, not assemblies.
CCarreiras
in reply to: chris
Hi!
Run this iLogic rule in your drawing:
This rule will rename the sheet name to the name of the model (part or assembly) present in the main view of each sheet.
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
MessageBox.Show("Please run this rule from the Multi-Sheet DRAWING file.", "iLogic")
Exit Sub
End If
'ilogic rule renames each drawing sheet to first part/model/ipn/etc view inserted into each drawing sheet
'Purpose: Push file name to sheet name
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = oDoc.Sheets
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
'Iterate through sheets
For Each oSheet In oSheets
	Try
		'Grab the first drawing view on the sheet
		oDrawingView = oSheet.DrawingViews(1)
		'Grab the model of the first drawing view
		oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
		'Assign the sheet name based off of the file name, with the path and extension removed
		oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName)
	Catch
		'There is no drawing views
	End Try
Next
InventorVb.DocumentUpdate()
 Tip:
You can add this rule to your template and start to use it in the new files, or use it as an external rule to use it when you like in any drawing.
I use it as an external Rule.
CCarreiras
m_mirasadi
in reply to: CCarreiras
Many thanks for sharing this awesome code.
Could you set this code to rename sheets from custom iProperties ?
