04-19-2024
02:47 PM
- Mute
- Permalink
- Report
04-19-2024
02:47 PM
Maybe you want to have a look at this rule. It is a bit complex when it comes to selecting the plane/point. (Line 31 to line 109). But the important part (and easiest part) is in the first part of the rule.
Public Class ThisRule
Sub Main()
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim selector As New Selector(ThisApplication)
selector.Pick()
Dim sketch = def.Sketches.Add(selector.SelectedObject)
Dim modelPoint As Point2d = sketch.ModelToSketchSpace(selector.ModelPosition)
Dim partNumber = iProperties.Value("Project", "Part Number")
Dim sketchText = sketch.TextBoxes.AddFitted(modelPoint, partNumber)
Dim textSketchEntities As SketchEntitiesEnumerator = sketchText.ConvertToGeometry("txt")
Dim markGeometry As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
For Each oSE As SketchEntity In textSketchEntities
markGeometry.Add(oSE)
Next
Dim markFeatures As MarkFeatures = def.Features.MarkFeatures
Dim markStyle As MarkStyle = doc.MarkStyles.Item("Mark Surface")
Dim markDef As MarkDefinition = markFeatures.CreateMarkDefinition(markGeometry, markStyle)
markDef.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
markFeatures.Add(markDef)
End Sub
End Class
Public Class Selector
Private WithEvents _interactEvents As InteractionEvents
Private WithEvents _selectEvents As SelectEvents
Private _stillSelecting As Boolean
Private _inventor As Inventor.Application
Public Sub New(ThisApplication As Inventor.Application)
_inventor = ThisApplication
End Sub
Public Sub Pick()
_stillSelecting = True
_interactEvents = _inventor.CommandManager.CreateInteractionEvents
_interactEvents.InteractionDisabled = False
_interactEvents.StatusBarText = "Select a LinearGeneralDimension."
_interactEvents.SetCursor(CursorTypeEnum.kCursorBuiltInLineCursor)
_selectEvents = _interactEvents.SelectEvents
_selectEvents.WindowSelectEnabled = False
_interactEvents.Start()
Do While _stillSelecting
_inventor.UserInterfaceManager.DoEvents()
Loop
_interactEvents.Stop()
_inventor.CommandManager.StopActiveCommand()
End Sub
Public Property SelectedObject As Face = Nothing
Public Property ModelPosition As Point = Nothing
Private Sub oSelectEvents_OnPreSelect(
ByRef PreSelectEntity As Object,
ByRef DoHighlight As Boolean,
ByRef MorePreSelectEntities As ObjectCollection,
SelectionDevice As SelectionDeviceEnum,
ModelPosition As Point,
ViewPosition As Point2d,
View As Inventor.View) Handles _selectEvents.OnPreSelect
DoHighlight = False
If TypeOf PreSelectEntity Is Face Then
If TypeOf PreSelectEntity.Geometry Is Plane Then
DoHighlight = True
End If
End If
End Sub
Private Sub oInteractEvents_OnTerminate() Handles _interactEvents.OnTerminate
_stillSelecting = False
End Sub
Private Sub oSelectEvents_OnSelect(
ByVal JustSelectedEntities As ObjectsEnumerator,
ByVal SelectionDevice As SelectionDeviceEnum,
ByVal ModelPosition As Point,
ByVal ViewPosition As Point2d,
ByVal View As Inventor.View) Handles _selectEvents.OnSelect
SelectedObject = JustSelectedEntities.Item(1)
If TypeOf SelectedObject Is Face Then
If TypeOf SelectedObject.Geometry Is Plane Then
Me.SelectedObject = SelectedObject
Me.ModelPosition = ModelPosition
End If
End If
End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
