Rich-T
in reply to: Rich-T
Thanks Wesley, given your comments about mouse click events I've changed tack and have the code below, which asks for an offset position instead
Ideally I'd like it to offer 3 options for text height (3.5/5/10mm) and to rename the mark feature in the browser and wrap it up nicely in a transaction so it can be undone easily.
        Dim oAssDoc As Document
        Dim oAssDef As PartComponentDefinition
        Dim oFace As Face
        Dim oSketch As Sketch
        Dim oEdgeLoop As EdgeLoop
        Dim oMinPt As Point
        Dim oMaxPt As Point
        Dim insPoint As Point
        Dim oTextPt As Point2d
        Dim oSketchText As Inventor.TextBox
        Dim oPartNum As String
        Dim myX As Double
        Dim myY As Double
        Dim newX As Double
        Dim newY As Double
        oAssDoc = ThisApplication.ActiveDocument
        oAssDef = oAssDoc.ComponentDefinition
        ' Pick a planar face
        oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select the face for a part number mark")
        ' Make sure it is a planar face
        If oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
            ' Add a sketch
            oSketch = oAssDef.Sketches.Add(oFace)
            ' Trying to choose an appropriate point
            ' Assume this planar face has one edge loop only
            oEdgeLoop = oFace.EdgeLoops(1)
            oMinPt = oEdgeLoop.RangeBox.MinPoint
            oMaxPt = oEdgeLoop.RangeBox.MaxPoint
            ' Ask for offset values
            myX = CDbl(InputBox("Enter X offset", "X Offset", "0"))
            myY = CDbl(InputBox("Enter Y offset", "Y Offset", "0"))
            ' Calculate new coordinates
            newX = oMinPt.X + (myX / 10)
            newY = oMinPt.Y + (myY / 10)
            ' Create insertion point
            insPoint = ThisApplication.TransientGeometry.CreatePoint(newX, newY + 0.375, oMinPt.Z)
			'0.375mm text offset - so that the text doesnt fall off the lower edge of the selected face
            ' Convert insertion point to sketch space
            oTextPt = oSketch.ModelToSketchSpace(insPoint)
            ' Add the textbox
            oPartNum = iProperties.Value("Project", "Part Number")
			'MessageBox.Show(oPartNum)
            oSketchText = oSketch.TextBoxes.AddFitted(oTextPt, oPartNum)
            ' Create a mark feature on the textbox
            Dim oSObjs As ObjectCollection
            oSObjs = ThisApplication.TransientObjects.CreateObjectCollection
            oSObjs.Add(oSketchText)
            ' Convert text to geometry
            Dim oTextSketchEntities As SketchEntitiesEnumerator
            oTextSketchEntities = oSketchText.ConvertToGeometry("txt")
            Dim oMarkGeometry As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
            For Each oSE As SketchEntity In oTextSketchEntities
                oMarkGeometry.Add(oSE)
            Next 'oSE
            Dim oMarkFeatures As MarkFeatures
            oMarkFeatures = oAssDef.Features.MarkFeatures
            Dim oMarkStyle As MarkStyle
			oMarkStyle = oAssDoc.MarkStyles.Item("Mark Surface")
            Dim oMarkDef As MarkDefinition
            oMarkDef = oMarkFeatures.CreateMarkDefinition(oMarkGeometry, oMarkStyle)
            Dim oMark As MarkFeature
            oMark = oMarkFeatures.Add(oMarkDef)
        Else
            MsgBox("Please select a planar face!")
        End If
